i have been looking for ways to heat things up when its cold out.
I installed one of those big RED canister heaters, 1500watt--?2500maybe??--, KATS brand(I think), that goes in the heater-hose system.
Those things get super-hot, real quick.
Where many fail in the installation of these is that they simply cut the heater-hose and stick them in; plumbed in thus, they only perform erratically, at best, if not at all.
HEAT GOES UP.
I installed a TEE in the radiator drain-****, with the red canister mounted to the left-side bottom of the frame/rail, then a 5/8 hose straight up to top of the radiator, then 90* ELL, then hose straight alongside the HOT battery-cable across the top of the radiator, then swept downward to a "Y" fitting into the lower heater-hose where it enters the engine-block.
Mounted thus, cold liquid enters the bottom of the heater/canister, boils, and is forced up the hose by convection, across the top of the engine-compartment, through the "Y", and into the engine-block.
When this system was on my old 6.9-IDI, it got the engine lots warmer, much quicker, than the freeze-plug element ever did.
On a ZERO-degree day, I could turn on this heater for a couple hours, and the temperature gauge would be climbing towards normal, before I cranked the engine.
If I wanted warm starts in cold weather, one of these canister-type heaters is the way to go.
