swampdigger
I've been searching for hours now trying to find an answer to this (instead of going to class)....
I know the C6 guts are slightly different between the two... like you'd need the diesel throttle valve modulator, and its slightly weaker...
I couldn't find this source again, but a month ago I read the BBF pattern is ALMOST a diesel pattern, except the top two bolts are slightly higher on the diesel?
Couldn't a guy just drill and tap those two holes on the IDI's adapter plate and be done with it? Find C6/6.9 flexplate, and use the 460 torque convertor?
Kinda curious, in case a big block C6 turns up on one of my scavenger hunts...
