onetonjohn
Subject says it all. Last leg in air intrusion battle. Tried hose clamps, but sill leaking.
Well if you are just talking about the return line on top of the engine then regular fuel hose is fine. I just received an order of Cohline 7x12 fuel hose for return lines. 7x12 metric hose is the original spec that the return line caps are designed for, and this is why 1/4 can be so tight--6.35mm vs 7mm.What would be best for return lines? Rubber or silicone hose?
