mikepotts
Starter diameter 4"
Amp draw Nom. 150-200A
Min. cranking voltage 9.6V
Engine rpm 180-250 RPM
Starter diameter 4-1/2"
Amp draw Nom. 150-180A
Engine rpm 180-290 RPM
Do note that you maybe condeming a good starter that just has a bad pull in solenoid with burnt contacts, The way I test starters is with a clamp on current meter and testing the voltage to the actual starter motor, not the main battery connection to the solenoid, this elimates false diagnosise.
Have you made sure all the starter bolts are present and not loose causing poor ground from engine to starter?
i dont know why i didnt think of the amp probe, ive still got my Fieldpiece HVAC meter with amp clamp from the old days. i did notice the starter was firmly in place when i changed the battery/starter pos. cable.
