Dsl_Dog_Treat
Continued to chase vibrations felt while cruising between 2-2800 rpms in 5th gear I still have the problem.
Last night while struggling for hints I noticed that I could turn the driveshaft and when the load is set on the rear punkin, I could see that the rear axle is showing signs of axle wrap.
Wondering if this could be a possible culprit.
Reason asked?
While cruising, the vibration is being transfered to the exhaust and is causing it to rub and shake up against the firewall (down pipe in particular) and the door panels are rattling pretty good(hence lounder stereo install ).
I can't feel any abnormal vibrations on the t-case and transmission shifters nor anything in the steering wheel.
Heck, I didn't even feel that the left front tire lugnuts were loose. ( having troubles keeping em tight on both trucks )
I have changed 2 u-joints that were bad and have cleaned the crud off the insides of the dually wheels.
I am in need of new shocks but the scratch for them is on the low priority list according to the bank of Karen.
The tires have been checked for balance when I was having flat tire issues last month.
I'm running out of places to look.
Anyone have an outside thinking of what might be going on?
Reason asked?
