Autometer pyro.
drudykj03
This qeustion is for you guys that have a autometer ultra lite pyrometer. If I drill and tap a hole in my exuast manifold will the probe screw right in? or does a bung have to be welded in??
Thanks
drudykj03
Also if I wanted to install a oil tempature gauge where would I get the reading from? Where or what would I tap into..??
sassyrel
iowa
bung needs to be welded in--use nickel rod---dont braze--as brazing dislikes vibration, and will crack out--can get the fitting from autometer--just call em------------oil temp of the crankcase, or trans?????
drudykj03
how does it fit into the probe fitting on a turbo then?? just curios
dont have it in front of me, just going to buy soon.. I dont have a turbo either. just hoping I could thread it right into the manifold... if not is there another manufactor that makes one I could do that with?
diesel4me2
Camping is more importanter!
northern illinois
i drilled and tapped my exhaust manifold and threaded in my pryo. as far as the oil sender goes i installed it in my oil cooler.
chris
Ironman03R
Risingsun, OH (NW OH)
I have an Autometer Z-series pyro and it has a fitting that threads into the manifold after you drill and tap it to 1/8NPT. The probe attaches to that.
ntjapkes
