prepowerstroke
hey i was thinking about buying a ats turbo for my truck.... what one do i want? like is there different types or what? ik i want a wast-gated.
Cause with a load on a nongated turbo it's works alot better an holds high boost. Loaded I can hit 14-15 psi. An I hold between 5-12 psi loaded. For freeway an towing non gated. Hills Around town runner some towing stuff here an there waste gated is better.
The non gated kits do run lower egt. an RDSL hit it on the head I floor it at the bottom of the hill an have let off to about half maybe lil more than half by the time I hit the grades peak. Blackdawg you are correct boost does come on a lil later than gated. I run 2700 RPM somtimes more on a grade loaded 15k gross.
My egt stay around 1,000 an if I lay into it underload at high boost egt's will drop. AS FOR TALKING ABOUT SMOKE you cant drive if your trucks a stick an your flogging the road I can drive my truck clean as a prius or BLACK out the road My choice its all in the pedal control (your foot) Unless automatic smoke doesnt occur unless its put there.
Also blackdawg is right boost comes on quicker in a gated kit when rolling around town or what not. I can have lil boost lag if its 0-whatever wot I build boost the hole time now when im out of it its gone. I cruse the freeway at 60-70 mph at 1-3 psi depends. Also it really depends on the driver an its use I have used an drove both kits an plan to put a custom turbo kit on my truck.
But I will never ever sell my ATS nongated 088 turbo its worth a million bucks its in the back out of the way of everything its clean looking minimal problems with the kit parts are out there silly easy gromet for drain GREAT KIT. I work on these trucks somtimes for people an I Charge More if its the 093 kit period nice turbo its in the way of everything I hate it but thats just me. Look up the 088 kit I really think you will like where it sets an how simple the kit really is. jm2c
