smolkin
Stuck inside Mobile
In the process of swapping the IP from the 6.9 to the 7.3 I discovered a "repaired" hard line that I don't like (it has a brass tubing union on it). Can I swap the hard lines too? The 7.3 has the timing adapter on #1, would the 6.9 lines work if I removed it? I was reading this tech article http://www.oilburners.net/forums/showthread.php?t=7639 which mentioned the 7.3 lines being slightly shorter...that shouldn't matter if I do the whole set, right?
