Anyone in NW TX who can weld?
Cubey
Van dweller
Is anyone around Amarillo or Lubbock who can weld? I'm north of Amarillo right now.
I need a couple of steel casters (bought already) welded on the skids of my RV. It was poorly designed so that it has to drag on steep slopes. The RH skid drags worse and it's almost worn down completely.
DOE-SST
1994 E350
I can weld, but you'd have to travel a bit further west...
to Albuquerque.
Cubey
Van dweller
Sadly I already drove through there, and I didn't have the casters yet. I thought to check the skids again last week and saw one is nearly worn down. So, so i can't put this off anymore. The pair of casters were $50 but it's what it needs. they are very heavy duty and can be greased with a grease gun.
ISPKI
Granby CT
Too bad I live up in NE, I would weld that up in a heartbeat for ya.
nelstomlinson
Delta Junction AK
Welding would be ideal, but if you take the rollers off, drill through the skid and through the caster frame, countersink the hole in the caster frame, then you could bolt it onto the skid with some short stove bolts.
Cubey
Van dweller
There's no room in the bracket for a bolt I don't think. I don't want them rotating either.
nelstomlinson
Delta Junction AK
I figured it would be too tight for a bolt head. Countersink the hole and use a stove bolt. The head will sit down in the countersink. Two bolts per each to keep them straight.
Welding would definitely be better.
Cubey
Van dweller
The skid isn't that big really. I wouldn't want to weaken it with holes for bolts. I'm sure I can find somewhere in Amarillo (45 miles on my way south) to have it done. I tried posting on FB groups and here first in case someone was nearby, by chance.
ROCK HARVEY
Dayton OH
You could always find a harbor freight nearby, and get everything you need to take a stab at it yourself for about $200. Even a total beginner can make strong welds, they just won’t be pretty. There are some really good YouTube tutorials out there to show you how to do it. You can always sell the stuff afterwards and get most of your money back too.
Cubey
Van dweller
Stick welders are cheap online ($70 shipped) but I'm not sure that's a good place to do a first time weld job, having to lay down underneath and work in such a tight space.
ISPKI
Granby CT
Definitely not ideal trying an overhead stick weld for a first go. Usually takes quite a bit of practice to be able to produce anything remotely safe on an overhead.
Big Bart
Tow&Slow
Newport Beach, CA
Try calling a couple of muffler, trailer hitch, or decorative fence companies. Explain it will only take 30minutes and ask what would they charge. Be sure to unhook all the batteries before they start. Maybe hit the breakers for the 110v in the vehicle.
TNBrett
Middle Tennessee
Keep your eyes open for a guy with a welding rig on his truck at any gas station, fast food joint, or Home Depot. I bet you could get those welded on for a 12 pack or two.
