apextrans said:
Also, where would I look for an RDT? NAPA or something like that? Where do they exit under the truck?
An RDT is really something you'll have to make yourself. I don't know of any auto parts store that make an "RDT Conversion Kit", and if they did, can you imagine the fit the treehuggers would throw?
It's very straightforward, though. You've already got the adapter that goes on the injector pump gear housing under the oil filler pipe, right? It should have been installed as part of the Banks kit. There'll be a hose on the nipple on that adapter that goes to the relocated CDR valve on the air intake...remove this hose from the CDR valve and find a way to plug the hole (I used a rubber expansion plug). You can then remove the hose from the adapter side and get a length of hose with the same inside diameter and hook it up to the nipple. Oil-resistant hose is best (you can get bilge hose from West Marine), but I'm just using cheap-o wasing machine discharge hose for now...it works, but the oil's eventually going to eat away at the rubber. From the nipple, you can run the hose anywhere you want. Just, keep in mind that at idle, white smoke will be coming out of the end of this hose...no harm done by this, except that there may be legal complications. So, finding a way to conceal this may not be a bad thing.
Also, whatever you do, make sure that the RDT hose is as free-flowing as possible!!! For that reason, although I can readily understand getting the hose exit behind the cab from a smell perspective, the shorter your hose, the better. If the crankcase builds up too much pressure as a result of the RDT not letting enough gases escape fast enough, those gases WILL find a way out...on my truck, they found their way out the front and rear main seals.
I was in a hurry, and put on a breathing oil filler cap at first, and that put too much restriction in the system...
Hope this helps some...good luck!!
