DaytonaBill
I'm going to replace water pump today but just wanted to know what the bolt sizes were so I can go get some and cut the heads off for dowel pins (2).
Also, I got the expensive thermostat but was confused by the wording on the rubber band around the circumference of thermostat. It says 'install facing the radiator'.
I thought the wax motor was supposed to sit in the engine block, exposed to the recirculating engine water being heated up thus expanding the wax motor which causes thermostat to open.
So, which is it? Wax motor in the block, or away from the block? I know this probably sounds like a stupid question
, but I don't want any cracked heads. Thanks...
