any chance anyone near me has timing equipment?
SPR1NK
Stevensville, MT
was looking through the timing registry and didn't see anyone that was very close, but maybe there's someone closer to Stevensville Missoula area that has timing stuff that isn't on the registry?
SPR1NK
Stevensville, MT
well maybe I'll just have to order the stuff to do it and see if i can get next day or 2 day shipping on it
SPR1NK
Stevensville, MT
i do make it to billings every now and then, but not very often, usually if i head there it's to watch the NILE rodeo
Macrobb
North Idaho
Hate to say it... but if you are using a used IP or injectors, just time it by ear.
A new IP and injectors, yeah, you can use the timing equipment, but anything used? The curves will be different than new.
Just adjust it back and forth until it feels the strongest, and you'll be pretty darn good overall. Timing is the #1 overlooked item on IDIs, and it's really not hard to adjust as long as you aren't 'scared' of it - you can't adjust it enough to do any damage, and the motor will tell you right quick if you are much too retarded or advanced.
Macrobb
North Idaho
everything is new, brand new engine actually, have R&D 90cc pump and R&D stage 1 injectors
Good choice on the parts!
edit:
I'd still probably time it by ear first off; you can always get it running nicely, then make any tweaks once you find a set of timing equipment.
TIMING BY EAR.
Advance the timing on a cold start till it clatters a little, it should then quiet down as soon as the Hi idle de-energizes and goes back to normal idle of 650 to 700 RPM, then you should be near perfect timing. Might take a few tries. Never move the IP with the engine running.
SPR1NK
Stevensville, MT
i have it running pretty good right now but I'd like to get the proper equipment on it and see exactly where its at
SPR1NK
Stevensville, MT
so if i was looking to buy the stuff to time (which i am) what would you guys recommend i get? i know i need the ferret adapter, but timing light recommendations?
BagdadRon
