Another what is it?
Selahdoor
Index Wa
I have been told that this has something to do with some kind of control on the E4od.
That white part looks like a vacuum line has broken off, or something.
Can someone tell me what this is, what it does, and how to test it?
Selahdoor
Index Wa
So I gotta hold a map up to it?
What if it don't like the map it senses?
Should I show it something specific? Like Timbuktu, or New York, which would it like best?
gandalf
Senior Member
CA &/or Maine
Which map does it want? That depends on whether you have a 4x2 hi-way queen or a 4x4 dirt eater. You have to give us more specifics.
MAP sensor= manifold absolute pressure.. You can Google that.
david85
Campbell River, B.C.
That sensor tells the transmission controller what your relative altitude is by reading atmospheric pressure. Engines generally lose Hp with altitude due to less dense air, so ford determined it was worth factoring this into the E4OD shift schedule.
What's shocking is that ford decided to leave this obscure sensor in plain sight so that it would be easy to replace when it fails.
Selahdoor
Index Wa
Does anyone know if there is supposed to be a hose on that?
Does anyone know how I can test it?
Jrlew87
