WarNose
i just replaced my injectors because the motor was making a ton of noise. I also put new return lines. The motor runs a lot smoother but it is so quiet now that I hear a knocking sound that I couldn't pin point before. I'm afraid its a rod knock at the rear drivers side of the motor. Here are a couple of links to videos of the motor running. You can hear it best when the camera is under the truck looking at the starter. What do you all think? Thanks for the help.
https://youtu.be/qHd21rRRbVE
https://youtu.be/2TJG92nYc9Y
