johnnynegaunee
Can anybody help me in my quest to make my '89 start easy at 0 degrees? I just put some clear tubing in my return lines from #1 injector to the filter housing and also from the pump top to to a metal line that goes to ? (a check valve) at the driver side rear injector. As soon as I shut it down air came into the line at the top of the injector pump. Is this normal? I see no sign of leaks accept the rear tank is damp with oil from the top above where the fuel line immerge Would an electric pump purge enough air from this system to improve starts? Thanks for the input.
