Still Strokin
Who the hell is OP?
Here are some pics to help show how the 093 WG is set up and hopefully help understand what i said in my last post.
in this one you can see the hole that the WG flapper covers, and then will "uncover" when your desired boost pressure is reached. For lack of better words the flapper sits on top of the hole. does not go inside the hole.
In this one you can see the flapper and the linkage in the outlet elbow with the down pipe attached to it. when the WG rod is pushed out of the WG head like i said in my last post it will push the linkage so the flapper will un cover the hole in the above pic, relieving drive pressure into the exhaust pipe.
BTW nice shop in the background too... I'm green with envoy...
