i just replaced both front and rear tank i did not remove the bed i removed the straps and disconnected them form the hoses and connector after tilting the tank towards the rear of the vehicle installed the same way no bed removal
Frame is recommended! I did two ratchet straps and well, the bed came off but not nicely. Was putting a flat bed on anyways.I did the same a long time ago on my '86 4x4 in sig. Never again. I pull the bed all the time now & take care of other things that need attention while it is off. If you have an engine puller, you can make a simple frame to attach to the arm and lift it off. Otherwise get 3 other friends to help lift off.
You are very right on that, never again.I did the same a long time ago on my '86 4x4 in sig. Never again.
When I realized the trouble I got into by damaging nylon fuel line I did in fact re-visit the option of removing truck bed.I pull the bed all the time now & take care of other things that need attention while it is off.
For the same diameter of nylon pipes - yes. But I need to join different diameter nylon pipes - remainder of original 3/8" blue line to new 5/16" from new push-on connector. Something like this would work perfect, if it were made for nylon pipes.Rubber fuel hose will slip over the nylon lines tightly + use hose clamps
Learn to do things yourself. This accomplishes two things. First, it helps you keep some of your money in your pocket. Second, it will give you some understanding of why things cost what they do.
