Dsl_Dog_Treat
Well brown delivered yesterday a non wastegated air stuffer for the truck formerly known as Goldilocks.
Thanks Calvin.
Need some advise as I do not have an installation manual.
Question 1: Fuel return crossover line on the rear of the motor. Relocate it to the front?
Question 2: Relocated oil line t-bracket placement for sending unit location.
I think it goes where the ground wire is placed for the GPC on the back left corner of the intake but think the stock sending unit may be into the firewall by time the cab is set back on. I also currently have a t plumbed onto the stock riser tube for the mechanical oil pressure gauge. Running out of room already me thinks.
My added t had to be removed due to the turbo exhaust downpipe manifold location.
Question 3: GPC relay location?
I have located a place locally that carries the replacement gaskets so that was a big relief to avoid Banks pricing.
I am sure there will be more questions as time goes on as yesterday was cleaning and familiarization day.
Tonight I wrench. :Sly Exhaust here I come.
For time being it looks like I will be sticking with the big box setup and will be able to play later with the other goodies. gotta get her back in paint first as the cab and box are outside under wraps in the weather and rust spots are begining to reappear thru the primer.
Thanks Calvin.
