Lost_Gasser
Okay, so after 4 weeks worth of waiting for parts, struggling with a bad back, re-ordering parts (don't ask) and stringing together foul language that would make an over-the-road trucker blush - I've got money pit put back together.
History: bought this thing with a horrendous back-fire through the intake. I mean it was bad - from idle all the way through the power curve. I pulled the heads and found an intake valve that was so badly burnt and battered that it only had about an 1/4 of an inch of seating area left on it. (I'll post a pic or two if anyone's got a morbid curiosity..)
So I put fresh (low miles - about 60K on them since rebuild) heads on the block and she started up like a champ. (1000 times better than when I brought it home - amazing what new plugs and a controller will do) After meticulous leak checking, radiator flushing and sca/coolant adding - I decided to take it on the madien voyage. (Runs great to this point!)
As soon as I put it under load I started to get some faint popping. Of course it increases as I get on the throttle. I'm kind of leaning towards a timing issue, but I wanted to see what you guys thought.. I've got it exactly where it was when I removed it - but theres about 10 marks on the IP and gear housing.
I don't have the equipment to time her - and I'll probably end up taking it to a shop and getting fleeced. I'm just hoping someone can say "Yeah moron, the truck needs to be timed - that's where the popping is coming from.." Oddly enough that would make me feel A LOT better...
As usual, thanks for everything - I couldn't have gotten this far without you guys..
-Josh
-Josh
