aaron1976
I just bought my first diesel and it is an 87 Ford with a 6.9 IDI with an ATS turbo.
The truck runs well but is hard to start at times. More on that later.
I have started to go through the truck and it looks like who ever installed the turbo was a diy-er and not a good one. The air intake piping is aluminum water heater vent pipe and is coming apart. The air filter housing is from a 90 or so F-150 5.0 gas truck. I don't think it can flow enough air and it is a mess. I will post a picture so you all can see how bad this setup was.
I got a hold of an airfilter canister from a semi or dump truck. It is about 9.5 inches in diameter and 17 inches long. I think I will try to mount it on the drivers side fender where the coolant over flow/windshield washer fluid tank is and relocate the coolant tank.
I have some 3 inch pipe that I am going to run from the air filter to the turbo.
Woundering if anyone else out there has done anything like this or has any good ideas for me before I do this. I thought it would be a good idea to get some input.
Should I go with 3.5 or 4 inch intake piping?
Have a good one.
Aaron
Have a good one.
Aaron
