so i got the orange orifice tube installed and recharged with 3 oz of oil and 2.80 lbs of Freon. the tube i took out was pretty dry so that's why i added some oil.
what i noticed was the large hose from the drier was starting to frost along with some of the fitting on the evap core. not sure if that is good or not. i did a fair amount of driving today with ambient temp at 85* and i was able to get a steady 58* from the vents. its better but not much. on long idle times it does stay cooler longer vs before it would go to 70* quick.
i thought i could smell some Freon or a/c oil odor while driving but it might have been me and it came and went.
any way, i still think the air should be a lot colder and if the evap can make frost then it should be really cold. i guess i will put a valve to bypass the heater core and see what happens. i have some pictures to show also.
