while working on my truck, i found a problem with the line on the cond. where the mounting bolt is? can i get this welded? i tried to clean it with steel wool?
Nope. Just find a shop that can make you another hose or go find that damaged end on any big Ford or Merc in a wrecking yard, cut it off and have it installed on your hose.... If your hose is worth saving. I really don't think the soft aluminum tubing is weldable T60-61....
