built4tq1
Anybody every used an a/c condenser for a trans cooler? I removed my a/c (dont need it were i live) And thought about maybe using it for a trans cooler. clean it out real good and throw some lines to it
The a/c condenser can obviously handle the pressure, but I'm not sure whether or not it can handle the necessary volume. Would be worth checking before going through with it...hopefully someone who knows more about it will give a more definitive answer.Anybody every used an a/c condenser for a trans cooler? I removed my a/c (dont need it were i live) And thought about maybe using it for a trans cooler. clean it out real good and throw some lines to it![]()
...I'm guessing either you moved to a cooler climate or you're Superman
...OTOH I'm miserably hot if it's above 70 degrees...The a/c condenser can obviously handle the pressure, but I'm not sure whether or not it can handle the necessary volume. Would be worth checking before going through with it...hopefully someone who knows more about it will give a more definitive answer.
And, I have to say...your "location" says Las Vegas, and you don't need a/c?!?...I'm guessing either you moved to a cooler climate or you're Superman
yes i moved to utah and it stays cool enough all year round for me to ditch the a/c
Be carefull what you use for a tranny cooler. Volume is what you want, the return oil is used for lubrication and cooling. Low volume can cause premature bearing failure, then **** goes the rest.
I imagine one could handle the volume, but it seems to me that most heater cores would be too small to really make a difference.Anyone ever thought of useing a heater core for a cooler, they can handle the volume ?
The diameter of the inlet and outlet pipes of the A/C condenser is at least 1/2", as compared to 5/16" transmission lines. Also, the condenser actually has two parallel paths through it, which also provides way more cross-section for the ATF to flow though than the cooling lines to and from the trans itself. Additionally, the fact that the lines and hoses are 5/16" does not mean you have a clear 5/16" ID opening for ATF to flow through all the way - in fact the barb fittings that are on the factory trans cooler in the radiator's bottom tank are only about 1/4" in inside diameter, so that's a bottleneck right there.And as said ac condensers are way too restrictive.
