geonc
SPIDER BAIT
I was changing out the oil cooler O rings today {thinking they were the cause of the leaking $9 gallon coolant } and when I lit it off I got this leak from the front cooler header to front eng cover
So there was the posibility that I muffed the gasket and drained the block and removed the bolts, slid out the gasket-----no nicks or anything, so I re-installed the gskt, filled and bled the system....no leaky ------till I lit it off--------------drip----drip----drip that is to the best I can see coming from the top/inside of the neck from the block cover and running down the boss the front header bolts to..........
Is this boss integral to the front cover or .......... ....
