'96 PSD aluminum front cover........
geonc
SPIDER BAIT
NECKVILLE North Carolina
I was changing out the oil cooler O rings today {thinking they were the cause of the leaking $9 gallon coolant :eek: } and when I lit it off I got this leak from the front cooler header to front eng cover -cuss :mad:
So there was the posibility that I muffed the gasket and drained the block and removed the bolts, slid out the gasket-----no nicks or anything, so I re-installed the gskt, filled and bled the system....no leaky cookoo ------till I lit it off--------------drip----drip----drip that is to the best I can see coming from the top/inside of the neck from the block cover and running down the boss the front header bolts to..........
Is this boss integral to the front cover or .......... :confused: ....:popcorn
94f450sd
somewhere,ma
not sure what youre talkin about but hopefully these pictures will help.let me know if you need pictures of a certain area and ill have them tomorrow night as i have my old motor sitting on the ground with no oil cooler on it.
geonc
SPIDER BAIT
:thanks: for the pic Rich :cheers:
Sadly the hailine fracture IS -cuss on the cast aluminum
neck that the front oil cooler header bolts to.
Your pic does not have the water pump installed so it is easier to see.
That Koolaid red CAT coolant shows up real nice oozing from the flange area- just under the upper cooler header mounting bolt....about 1/2" long running down the middle.
Apparently the back of the thread bore broke away..... cookoo cookoo .......:frustrate :frustrate
Looks like the entire front of the eng needs to come off----w/p, HPOP,crank damper, front oil pan bolts etc......... DAMNIT MAN!:mad: :mad:
Now to find one..............:popcorn
94f450sd
somewhere,ma
actually the whole engine has to come out to replace the front cover.you need to remove the oil pan so that you can unbolt the oil pump pickup tube from the cover.ford/IH used a gray RTV for the oil pan gasket.this stuff is like cement.i broke 2 huge screwdrivers and one gasket scraper,and dented my oil pans trying to break the seal to get the pans off.in the second picture i posted above you can see the oil pump pickup tube.
94f450sd
somewhere,ma
oh and the damper needs a puller to remove it.the normal harmonic balancer puller that you can rent/buy from advance and autozone wont fit it.you need a bigger puller for the PSD balancer.the timing cover gaskets are O-rings and are 100 bux from from ford,probably cheaper from IH or www.powerstrokeshop.com .
geonc
SPIDER BAIT
:eek: :eek: ................... -cuss -cuss ........:frustrate
Ain't that just VULCAN great :puke: I guess I can add that aggrevation to however much $$$$$ that cover is gonna cost ;Really
Anyone ever see them parted out...
...or do I just get bred at the stealership :rolleyes:
94f450sd
somewhere,ma
check ebay or ask around on www.superdutyduydiesel.com .id sell you mine but i made some modifications to the one on my new motor and dont know if its working properly or not yet and not sure what im doing with my old motor yet.if you can see the crack you can always take it down to a welding shop and see if they could weld it in the truck.dont quote me on it but i believe the cover was a little over 100 bux from ford.
yankin the motor isnt that difficult.and its the perfect time to replace the up pipe donuts,turbo pedistal O rings and gut the pedistal or buy a modded pedistal or modify yours to remove the EBPV actuator.
geonc
SPIDER BAIT
Well this cannot be welded in place.........or I'd already done it :D
If you picture the {scrawny :puke: } neck the front oil cooler header bolts to....the fracture is just below the upper bolt and faceing the rear....NO acess even with the oil cooler header removed -cuss -cuss
AND just who was the idjit ingunieer that thought up the mount for the front cooler header :backoff :backoff
I'd like to shove a GM 6.2 up his *** and START IT :Sly
The IDI design is FAR superior and easier serviced :hail
Whut mods can you make to the front cover :confused:
BTW....howdjknow my up pipes were leaking ;Really LOL :D :cheers:
94f450sd
somewhere,ma
94f450sd
somewhere,ma
HOLY S*&T!!!!!!then when i thought i needed one they gave me the price for something else. :eek: :eek:
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
George, this is a perfect opportunity...come back to the light side!! :D
I'm sure it's far easier to drop an IDI in place of a PSD than vice-versa :D
Seriously, sorry to hear of this...hopefully you don't uncover anything else!!
geonc
SPIDER BAIT
Tim, don't think for a moment THAT very thought hasn't filtered thru my grey matter :Sly ;Sweet :D
{inner voice speaking and I quote---------
-- '94 IDI turbo = big rods, oil cooler{that is MUCH easier to service} along with nozzles and GP's service, you can still have that ;Sweet ;Sweet turbo whistle :Sly .......all you have to change is the PSD badges :eek: ;p :D }
OH BOUY...decisions, decisions LOL ------:popcorn+:cheers:
Rich....the parts guy said he could smell smoke comming from the phone :eek: :draw
Mike
Stroker
Cora
:backoff
SWONK!!!!!!!!!!!
Mike
Stroker
Cora
Then you'd just be a PSD poser...........
:backoff :backoff
DOUBLE SWONK!!!!!!!!!!!!!!!
dented73
