Dsl_Dog_Treat
92 460 F 250 wont start with the key
As the title says no start by key. Will jumper off the solenoid tho.
The truck was running fine up until last week then died.
Fuse popped for the odometer memory then would not start by the key.
The neutral safety switch and ignition control module have been replaced.
Ignition switch is confirmed functioning.
I'm running out of ideas as to what could be causing no signal power to the solenoid.
Everything I'm testing is checking out ok.
I'm about to give up on it as I've got 10 hrs into troubleshooting this one and my buddy needs the truck back and needs it right.
I hate electrical issues!!!!
