91 f250 7.3 e4od 4x4 shift trouble
93cc7.3
needs turbo power
plainfield IN
hello all my friend bought a 91 f250 ext cab 4x4 with a e4od 900 bucks .....
here is the major issue
shifting trouble
once warm reverse doesnt work until you rev it up a bit
1-2 shift is hard
under hard accel leaks trans fluid
and lastly the shift indictor on colum is off as well as it says 4x4 is always on except in tcase neutral postion
i know alot of stuff ...
im replacing the vss & neutral safety switch tonight the tach works and the od light works properly as well
thanks for future insight .... im glad my truck has a zf5
flareside_thun
Reviving The General Tao
Tavares, Florida
Uh oh....that sounds like the pump is going out(with the lack of reverse) which means, it's not long for this world. Shifting issues can also be caused by an out of range TPS as well.
93cc7.3
needs turbo power
plainfield IN
ok some things firgured out but now that i have the truck in my garage once warm you have to rev it up for it to move in any gear is this a filter issue
trackspeeder
Stone crusher.
North Branford. CT
This is a little more than a filter issue. What dose the fluid look like? Best thing to do is drop the pan. Take a look see if there is any carnage in it. If you can pressure test it. Most likely the tranny is tired. Time for a rebuild.
93cc7.3
needs turbo power
plainfield IN
ok dropping pan tonight if i replace the filter will this damage the tranny the po claimed it was rebuilt along with motor ... the motor was found that out but there is no paperwork on tranny so it cold be low miles or 400k
93cc7.3
needs turbo power
plainfield IN
ok ell ive heard changing a filter on a high mile tranny can apply to much volume to the pump or something its something ive heard more than once just wondered
93cc7.3
needs turbo power
plainfield IN
dropped the pan filter sitting in the bottom of it they tranny was rebuilt along with motor and tcase but they didnt put the filter clips in it so now i gotta find those somewhere
trackspeeder
Stone crusher.
North Branford. CT
Check for the old O ring in the pump. Most of the time if the filter falls out, the old O ring is still in the pump. The incorrect filter (4X2) will fall out if used too.:eek:
Majority of the E4OD's didn't use the band aid clips on the filter. Good chance that tranny didn't have them. That's why they didn't put them on.:D
93cc7.3
needs turbo power
plainfield IN
ya after i posted that i did some research and ya the old o ring was in the pump ...
so my question is... is this going to happen again i know they make clips but cant find them locally also so ppl put 99 super duty pans on them for added cooling and those pans have perches to hold the filter
trackspeeder
Stone crusher.
North Branford. CT
Lube the new O ring and press the filter firmly in place. You will feel it seat. The filter will be fine. I use the 4R100 pan in place of the early pan. Dumping the fluid out of the early part sucks. Besides the 4R100 pan has a better rail design and uses a re usable gasket. No leaks with this sucker.:thumbsup:
crispy74
