dukedrummer89
I recently bought these axles out of a 1989 F350 with roughly 130k. I was told they had 410s in them but after I got the diiff tag cleaned i found they were 3.55s, which is a little to high for what I planned on useing them for and I dont want to spend the cash to regear plus Ive found a 410 geared axle set local so im putting these back up for sale.
These are most likely going to be the most complete set you will find unless you buy a whole truck. The only thing that I can see that they need is a u-joint for the pass front.
The front come with everything shown in the picture, plus the rear frame brackets for the front axle, and the pitman arm. The rears still have the leaf spring and shackles and also the brackets for the frame. But the rear axle needs new ubolts (I cut them to make the rear axle easier to move around)
Im asking 1200 for the pair...local pickup only and im in peoria Il
