1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
88 f250 saved from savage nature
Discussion in '6.9L IH & 7.3L IDI Diesels' started by wrecked, Oct 17, 2020.
  1. hacked89
    hacked89 Full Access Member
    361
    388
    May 30, 2018
    Bucks County PA
    Yea the bed is from a different model truck possibly different manufacturer.
    More than even the lines (looks don't bother me), the beds wheel wells aren't centered over the axles. And the functionality of that would drive me nuts.
    If you tried to run over size tires it would probably rub.
    Sent from my SM-G955U using Tapatalk
  2. snicklas
    snicklas 6.0 and Loving It!! Staff Member
    46
    5,705
    1,695
    Aug 7, 2006
    Greenfield, Indiana
    To me it looks like a Squarebody Chevy body line.....
    Like I hate to see a Brick/OBS bed on a Bull........
  3. david85
    david85 Full Access Member
    4,321
    527
    Feb 21, 2008
    Campbell River, B.C.
    I think I've seen them before, but on a chevy square body.
  4. wrecked
    wrecked Full Access Member
    58
    47
    Oct 5, 2020
    Cariboo country BC Canada
    I'd say it's driving me sane!
    First proper winter drive
    Ya, I'd say I'm happy with it. I wandered around it for a good 20 minutes to get that shot.
    Went out on 80psi all corners, but drove home eventually on 50-55. Gonna go 45-55 tomorrow. At 80 it was undrivable to be brutally honest. At 50-55 it was so much better... damn this is a fine truck -- if I might say so me-self.
    Danielle and chillman88 like this.
  5. wrecked
    58
    47
    Oct 5, 2020
    Interesting failure this morning. I should mention it was -18... Ran the block toaster for 2 hours, put the key in -- it felt kinda snug turning the barrel -- and... nothing. Over-rotated it a fraction more and the glow plugs lit up. Held it there till the light went out and had to twist firmly to get the starter engaged. But she fired fairly quickly, only the moment I release it shuts off. Clearly I'm gonna be pulling the wheel and cleaning a lot.
    I've got a radiant heater on 500 watts in the driver's seat right this second, just to make things go slippety slip. Might get it to drive too, so I can eat my breakfast burritos.
  6. david85
    4,321
    527
    Feb 21, 2008
    Ignition switch on the steering column may have shifted on you. Or it could simply be worn out and the cold temperature (Celsius, I assume) was enough to make everything stiff enough to notice.
    wrecked likes this.
  7. chillman88
    chillman88 Supporting Member Supporting Member
    4,186
    3,270
    Feb 22, 2017
    Central NY
    I'm betting the actuator in the column broke, unfortunately a very common problem. Definitely worth checking the ignition switch like David said.
    wrecked likes this.
  8. wrecked
    58
    47
    Oct 5, 2020
    Indeed. Just found a rod that runs down the column, thinking the actual switch must be down there. I'm in a hurry to go tree hunting so I guess I gotta wake up long dormant brain cells from my miscreant days if heat and a can of spray lube doesn't work.
  9. wrecked
    58
    47
    Oct 5, 2020
    Not sure if this is good news or bad...
    Bumping along back roads likely popped the grey plastic part away from the base. Lots of copper in there I'm hoping lines up when I press it back on the snaps. No missing springs neither. Might use some baler wire.
    You know, this note 9 is a miserable thing to type with. The AI (artificial incompetence) constantly substitutes the words I write with complete nonsense! Good thing it'll soon be your doctor, or judge eh?
  10. wrecked
    58
    47
    Oct 5, 2020
    It's fixed, Saskatchewan style!
    But I've lost me mojo. It's after noon now and my back is killing me. One job I flat refuse is stereo installs, for no amount of money.
    Besides, the trees tend to forage higher in the hills as the day goes on. A neighbour owes me, says he's got a big old jug of homemade wine what tastes like fresh dressed moose. Gonna try some. Cheers for the tips peeps.
    Jason1377 and chillman88 like this.
  11. chillman88
    4,186
    3,270
    Feb 22, 2017
    Central NY
    Well I'm glad it was that simple! Might not be a bad idea to replace that ignition switch when it gets warm again. I prefer to drop the column to do it.
    Jason1377 likes this.
  12. IDIBRONCO
    IDIBRONCO IDIBRONCO
    6,528
    4,753
    Common enough that I'm done with dealing with it. I'm running a push button for the starter in my trucks. I don't think the actuator will break between the "off" and "run" positions.
    Mine did this in my Blue Truck. I used plastic zip ties to hold mine together just in case there was some bad insulation on a wire. No shorts that way.
    wrecked likes this.
  13. YJMike92
    YJMike92 Full Access Member
    488
    254
    Aug 10, 2018
    NW Arkansas
    If t's going to break, It will do it in the cold.
    IDIBRONCO and david85 like this.
  14. IDIBRONCO
    IDIBRONCO IDIBRONCO
    6,528
    4,753
    One of Murphy's laws. I'm really hate that Murphy guy sometimes!LOL
    YJMike92 and chillman88 like this.
  15. wrecked
    58
    47
    Oct 5, 2020
    I saw other potential issues lurking in/under there -- sticky turn switch, steering lock and the key barrel is quite sloppy and loose. Imma fix that whole situmication up proper, including the cluster, wiring etc. Ran out of zap straps... Reckon another momentary dash switch won't kill me.
    I haven't yet made the bracket for the glow plug button so I'll just make it bigger and get a slightly different button. Or look more closely at a floor button... I was also planning a to rig a throttle cable out the nose but could route that into the cab I suppose...
Share This Page
