85 cclb f350 cumapart swap
BrandonBerkosky
Dickson city pa
Called Jesse at high angle driveline for thos baby. It's the slipper for the t case and its a 1480. U may ask y 1480? Well i had all the parts and shafts laying around to make my own shafts with 1480 joints so i am into all the shafts for about $325 after new joints. I also got a blank 4.75 square flange yoke for the sterling bc i thought my driveshaft was a 4.75 square. Well it wasn't. But thats what lathes and mills are for!!! I got her drilled out right and made the pilot ring to match.
BrandonBerkosky
Dickson city pa
Rear shaft. Like i said all 1480.
Dont give me a hard time about balancing. I've made more shafts than i can count and never had a n issue
cpdenton
Truck needs paint.
Conway AR
This is great info for me. Starting to get interested in doing this to my 92. Thanks a ton for all the pictures.
BrandonBerkosky
Dickson city pa
no problem. glad I could help. ive had many idi's I even put one in a 1974 IH one ton. theyre great I just cant wait to start melting the back tires off this truck with the cummins.
BrandonBerkosky
Dickson city pa
time to install the turbo. in the background if ur wondering is a Hudson pacemaker im putting an IH 304 into to repower it. people get a kick out of that one.
BrandonBerkosky
Dickson city pa
Most recent update. I had the engine accessories setup with a hodgepodge of industrial and dodge stuff. I ended up going all industrial. I like the school bus off the shelf gm alternator over the dodge first gen alt that needs a kit or sonething to work without a computer
I also ordered a diamond eye 4 inch exhaust and I'll be integrating a Jacobs exhaust brake.
laserjock
Almost there...
These nut washer combo things ALWAYS rot away so i made my own from some lug nuts and washers. Then i just faced them on the lathe.
That is a great idea. What are the lug nuts off of? Looks great.
laserjock
Almost there...
I actually have a clean set of originals but thanks. I had actually thought about Making a set out of 6061. I have access to a little CNC that would make short work of that. Think aluminum would be tough enough?
BrandonBerkosky
Dickson city pa
Truck is done. I'll be tagging it this week. All I can say is holy crap. It's ridiculous. I've only ever messed with IDI's. I can't believe how these things pull. In every gear. Even in 6th gear on the highway. U roll into it it it wants more. I definitely need traction bars. I had to be very smooth when what I really wanted to do was sidestep the clutch. To anyone considering this swap I say get on it.
cpdenton
Truck needs paint.
Conway AR
Can't wait to see the videos.....:peelout:popcorn
If it weren't such a far commute, I'd come check it out personally.
trackspeeder
Stone crusher.
North Branford. CT
You wont need to side step the clutch with a CumminGs.:D Let it out and mash the go peddle.:peeloutLOL
truckonfire
