dukedrummer89
Long story short I overheated this motor and somehow it developed a rather large oil leak. Im half convinced its a head gasket, but im not sure and im pretty set on a cummins swap.
The motor is an 85 6.9, has over 200k on it, and still runs fine. It just leaks oil bad and smokes pure white under load.
It has an ATS 093 turbo kit on it (the one with the full 3in down pipe), a solid mass flywheel and 12in LUK clutch, Pensacola Diesel reman pump and injectors that have 5k on them, a new starter, alternator, and mech fuel pump. Reciepts for the new stuff... Also has a serpetine setup off a 93 7.3 motor.
Id like to get 1500 for the whole thing... if I parted it out id like
800 for the turbo setup
300 for the SMF and clutch
300 for the pump and injectors
200 for the serpentine setup
150 for the block an heads
Prices are obo, and i could ship everything but the whole motor
