OOPS--BY BAD The code is 39, which is 3.55:1. I should have known better than to have posted when I was tired and from my memory. FWIW the rpm's are about 1700 or so at 60 mph. Still checking the fuel mileage. I found a leak in the rear tank after I topped it off, it didn't look too bad however it only took me 200 miles until the gauge registered almost on E. NOT GOOD. I will see what the front tank returns. The engine starts like a new one, seems to run fine-I am driving mostly on cruise @60 MPH and slow starts otherwise. Still need to check the tire pressure but with almost new rubber [10 ply] it should be OK.
As stated earlier, it has the automatic trans, and yes, the overdrive is working. The truck will coast with little effort thus I don't think I have a dragging brake, but a tire spin while on a jack will soon be in order.
