Many people underestimate the effect ambient temps can affect a motor. Even more so our motors.
Part of this is simply that as a NA motor, it's running right at the maximum fuel point all the time to get that HP out, so there isn't much in the way of 'spare air' available for changes in density - It's pretty much air-limited the whole time(when you are using that HP)
Check this out:
http://bankspower.com/magazines/show/486-Banks-Sidewinder-Turbo
There's some very useful info in there.
Also, I'm pretty sure that engine wear factors into it far more with a NA engine than a turbo engine. With a stock IP(at the time) and Sidewinder turbo, I had a slobbering worn-out old motor that ended up having .020" of bore taper(!). It still ran fine, but was a little weak off idle. Once you hit 2K RPM and the turbo kicked in, it would pull hard.
I had it rebuilt, and despite having other issues, it really made a difference down in the "NA" range where the turbo isn't doing much... but once the turbo kicked in, it felt the same - to the point that I was feeling a bit underwhelmed by spending a bunch on a full rebuild.
I never did a before/after comparison on the dyno, but that would definitely have been interesting.
Oh, and the one NA IDI I've seen run on a dyno locally? Made 85 HP(this is at 2k elevation). So there's definitely some loss with engine wear, especially with a NA motor.
