7.3 IDI 9047 PT Fel-Pro Head Gasket COMPRESSED Thickness
MasterChiefIDI
Mississippi, USA
Thought it might be helpful to document this here for others searching in the future and to make my sacrificed head gasket worthwhile..
I can confirm the FelPro head gasket after being completely torqued down in 3 steps using studs at a final torque of 125 ft-lbs, the compressed thickness is .068" for the graphite/fiber area and .076" for the firing ring. I was using this gasket while using playdoh to check my piston to valve clearances.
I wrote down the before measurements. I will get those and update here.
You're welcome :)
Olds64
Edmond, OK
The question is, does that FelPro gasket keep the OE compression ratio? Thanks for sharing. ;Sweet
