6.9l to 7.3l swap
erikbala
Ride rank make Bank
Ellensburg/WA
my 6.9l has zero compression on the six hole
have a chance to buy a 7.3. just curious if there are any suggestions out there for me. and if my manual tranny can bolt up behind the 7.3l in place of the auto tranny.
thanks fellas
biggin92
Yeeeee Haaawwww
umatilla fl
i second that you'll just have to re-wire the 7.3 glow plugs but its really straight forward pull the 6.9 and drop the 7.3 in .
subway
be nice to the admin :D
York PA
externally they are basically identicle unless the motor was from a van, then there are a few differaces like exhaust, oil cooler and fuel filter.
Do you know why #6 is dead? I'd certainly take a look before you condem it.
What made you feel the cylinder is dead. Have you pulled the valve cover and looked at the springs or pushrods. Might be a simple fix.. Any motor noise thats got you thinking something came loose in the cylinder....
erikbala
Ride rank make Bank
Ellensburg/WA
i was climbing a long grade when i lost a lot of compression took a look behind me and it was just a black cloud. pulled over it was running really rough thought it was injectors but turns out thats not the case
i had it compression tested, but i figure if i can get the 7.3. i can start digging in to the 6.9 and rebuild it.
thanks for the suggestions guys much appreciated
FORDMAN41291
Herndon, KY
now i know pushrods are a somewhat simple but can be tiddeous replacement... i would liek to know if your stil goin to do the swap? keep us updated.
hesutton
The Anti-Anderson
Bowling Green, KY
so i took the valve cover off today bent push rod and broken rocker
:eek::eek::eek:
That's not good. Any chance you've gotten the head off to see what happend to the piston. Gotta guess the valve/piston gave each other a little kissy.
Heath
erikbala
Ride rank make Bank
Ellensburg/WA
well every thing is put back together decided not to swap in the 7.3
shes back running strong.
