6.9 vs. 7.3 nosie differance
dsblack
Washington State
Ok, I just got finished working on my friends 86 f-250. I noticed his 6,9 NA rattles a lot more than my 7.3 turbo. Is this normal? or is mine timed wrong. He seemed to have a lot of power for a NA 7.3.
thanks
Doug
h2odrx
Anti-O
Coastal Neckville, NC
thanks
Doug
I'm cornfussed???
is his a 6.9 or is yours??? :confused:
Mr_Roboto
Elyria, near Cleveland Ohio
The only difference in noise will be timing, the 2 engines are essentially the same besides cylinder bore.
A small change in timing can make a tremendous difference in noise level. When I first got my wrecker, the motor rattled so much at speed I thought it had bad bearings and I was afraid to take it over 60 mph. After backing off the timing, I can run it at 75 mph (with 4.11 gears!) with no problems.
Black dawg
sw mt
timing makes a big diffrence in noise level, but alot of other things can affect the sound of the rattle, if you listen close very few sound the same.
The 3 I've got pretty much sound the same. They are all timed to spec, which is why. The exception now is the Moose Truck which runs a DPS pump, and injectors, so that's a big difference, but before that, they were all the same.
brb5
