6.9 short block--used Ford/International
Michael Fowler
Bel Air, MD
I believe I will finally part with my extra 6.9 block. It is the later model with the reinforced web at the heater location. Comes complete with crank, rods, pistons, cam, pan, etc. In fact everything except injection pump and heads, and one valve cover. It does include about 4 head's worth of valves, springs, keepers, etc.
No lifters, or pushrods.
IIRC, the original factory hone marks are visible in the cylinder bores, at the bottom.
Engine will require a rebuild before installing heads, but I believe it to be in good shape.
Engine is located in Arbutus, MD, and would have to be picked up there. I have no crane to lift it.
Michael Fowler
Bel Air, MD
