4.56 gears???
what do you think?????
  • Keep 3.55s and use 4lo
    Votes: 2 12.5%
  • 4.10
    Votes: 7 43.8%
  • 4.30 gears
    Votes: 1 6.3%
  • 4.56 gears
    Votes: 5 31.3%
  • 4.88 gears
    Votes: 1 6.3%
  • 5.13 gears
    Votes: 0 0.0%
  • Total voters
    16
Farmer Rock
Glen Rock,PA
I have a super duty Dana 80 5.13 rear sitting in the parts truck, but it's 10 lug, and for a cab and chassis truck. The frame is narrower than my pickup.
It's an idea though. If I can find lug pattern adapters to have it the same pattern front and back. I would have to do some figuring on the mounting of the axle, but it may be worth it, so I only have to swap gears up front.
Rock
Black dawg
sw mt
The problem is the gear ratios in the transmission.
My favorite set up so far, was 3.55 with a wide ratio t19 out of an 85 460 pickup. Truck was NA 7.3 and it pulled a trailer far better than any NA truck I have had or been around. Never pulled real heavy with it, never over 10k, but never felt it needed turboed.....and that is highway towing over passes.
I am getting ready to put 3.55s in mine, and an old 435 4 spd in place of the close ratio t19. I have an OD unit I can split gears with and get cruising rpm down. Tired of it being borderline or worse of needing to use low range just to get a trailer moving.
jhenegh
Truck Still Earns its Keep
Deerfield, WI
I have a F-Superduty 4x4 I’m about to sell…FYI
With its 5.13 gears, 235-85-16, and zf5 it’s spinning ~2850 rpm to go 65mph. Screaming by my standards, but doable. It’ll do interstate well enough at 65 but 60mph state highway is a joy. With 5.13 you can definitely use all 5 gears all the time.
Oh and it still has manual hubs so it’s got 2wd low range too as well as 4lo/4hi
Farmer Rock
Glen Rock,PA
What are the details of the truck? Any pictures?
Rock
Jackieboy
Plainview, tx
Look around for a brown light, splice ect. Makes them. Then you double up everything and still have cruising economy.
jhenegh
Deerfield, WI
Rock
It’s a May 1994 truck with … a Powerstroke… ZF5, Quigley 4x4 conversion. 134k miles. Cab has rust but is serviceable for a few years yet or isn’t too far gone to fix the rust right now. Mounts are good, rockers are holey. 14’ flatbed.
I’ll post more details in marketplace when I put it up, don’t want to break discussion rules, but it is a great example of 5.13 capabilities!
u2slow
bilge rat
Coastal BC
You have to see if the pickup spring spacing (45"ish) can land on the f450 dana 80 without interfering with the brakes.
DrCharles
West Plains, MO
I think you mean Brown & Lipe aka a "brownie", or a Spicer? Either way, an auxiliary transmission :) I put a Spicer 5831 in my '65 F-350 (behind the NP435). It's fun to upshift in reverse, twice :D
