I'm considering swaping my 4.10's out for 3.55's or 3.73's to get better highway mileage. Of course a GV would probably be better, but I'm on a tight budget and can do the gears pretty cheeply. I'll probably hang on to my 4.10's just incase a GV comes along later on.
My truck is a 94' F-250 IDI factory turbo, 4.10 gears, E4OD and 100% stock. I primarily use it to pull a <3000 lbs enclosed motorcycle trailer.
I have carefully measured my mileage empty and have found that I consistently get 20mpg @ 55mph, 16mpg @ 65mph and 13mpg @ 75mph. I have thus restricted most of my driving to a max of 60mph, but that gets very old on a long trip. I know there is increased wind resistance at higher speeds, but I suspect that much of the rapid dropp-off in mileage has to do with engine rpm and thus mileage at higher speeds might be greatly improved with taller gears.
I have not done any real scientific measurements with with trailer but am getting around 17mpg between 55 and 60mph pulling the trailer. If I could get these numbers (i.e 20 empty/17 towing) at 65-70mph rather than 55mph I'd be really happy
My concern is that the taller gears may kill it off the line. I don't take off fast, but I don't want it to be a total slug either. Still, as it is now first gear seems pretty short and perhaps it wouldn't be bad with the taller gears.
So any comments, recomendations or whatever would be very much appreciated
click for bigun
BTW I'm the same bikepilot as on TDS and FTE and like many others seem to be migrating away from TDS....
click for bigun
