apextrans
What Log Book????
A while back I got t-boned & only found out recently how extensive the damage really was. Turns out my rear is bent & in the process of hunting down a Housing or a complete rear, I discovered the truck has 3.55's in it. I was told it had 4.10's althought never verified it. I figured the the Fire dept. would have specd 4.10's to pull the extra weight the truck carried.
This thing is turning 3000 rpm @ 75 MPH going thru a C-6 w/ a BW1356 t-case turning 285/75/16's. I didn't think that sounded right so I checked the front axle tag which shows a gear ratio of 3.54.
If anyone with either ratio could let me know what they're turning in the RPM range, it would be much appreciated.
Scott
Scott
