2wd to 4wd conversion
rjjp
Needs to go test
Clare, Mi
90 2wd
91 4x4 inside
91 4x4 outside
MUDKICKR
NITRO WV 25143
when i converted my dually into 4wd i found 5/8 plate steel and cut me out some spacers to make up for the 4wd pressed in place.
gunz
Yukon Oklahoma
you have to remove thr rivets from thar core support mount and install bolts. There is alot you can do ahead of time to help speed the process when the time comes. I have the front mounts installed and drilled, The nitches cut out except the very last little bit to allow the swap bar to stay till I ripped out the TTb stuff.
lindstromjd
Black Sheep
West Des Moines, IA
Ok, talked to the guy again and got pictures, it's definitely a straight axle. It's also a single cab F350 truck. So now I just have to figure out what order to do everything in, and what rivets and holes to drill out for the swap.
7.3_IDI_guy
Currently ******'
Spencer, TN
So is the parts truck a 4x4 dually or are you gonna have to find some dually hubs for the front end? because trust me.... NOT EASY TO FIND. done tried lol, I looked and looked when I had my 86 ton dually 4x4
7.3_IDI_guy
Currently ******'
Spencer, TN
heres my old 4x4 dually :sly those hubs under those simulators... very scarce. also ifyour makin a 4x4 dually. get some 10 lug adapters and run 19.5's ;Sweet
P.S. that bed wasn't my fault :puke:
sassyrel
iowa
YUP!!!!!!!! dana 60 i ton 4x4 dually,,and 1 ton 4x4 single wheel rear,,are diff front hubs,rotors,etc..................
lindstromjd
Black Sheep
West Des Moines, IA
So my 2wd front hubs won't bolt onto the 60? Crap... I didn't know they were different. Guess I gotta look for those now, too.
http://www.oilburners.net/forums/showthread.php?35474-d60/page2&highlight=DANA+60+CONVERSION
page 2 post #25 details via pics the steps needed to convert a OBS frame from 2wd to 4wd.
You'll be surprised what other members have already done and painstakingly documented here.
"dana 60 conversion" was the search words I used to find the thread btw.
Thanks for that... I thought that the bricks had different frames than the OBS's though...?
cheap bronco
phx, az
heres my conversion, its on a different site, but my bronco will soon be a 7.3 idi diesel so thats why im a subscriber to this site.
http://www.fullsizebronco.com/forum/showthread.php?t=201134
also check out their SAS conversion section alot of helpful and useful info
http://www.fullsizebronco.com/forum/forumdisplay.php?f=29
I put the schackles in the rear beacause I read the FAQ's section on the fullsize bronco site and it made sense that when you hit a bump going forward the momentum of the vehicle and the movement of the axle is going rearward just like the rear axle does.
You may need to subscribe to view pics, If you dont I can lend you my login info for a bit. let me know if you have any questions.
tke395
