mariobusalacch
Soryy I didn't post this earlier, but I was just to excited to get this thing running, but here it it now! I am a proud new owner of a 94 turbo charged diesel,my first one! I saw this truck up the street from me, caked in dirt and spider webs so I asked if they were selling it, long story short I picked it up for 2500, thanks to towcat..........also thanks to towcat and you guys it runs beautifully now. First it would take forever to start then it would just die right away unless u held the acc., after about 5 min of that u could let off and it would idle rough...well alls I did was drain the tanks and fill them up with injector cleaner, and put in a new fuel filter. Then I draind the coolant and refilled that....I starteds it to let it idle through, just let it get use to running, then a coolant line cracked, replace that, then next a fuel line cracked so I replaced that, I bought extra of both just in case.........the next problem was the gov springs were sticking, thanks to your guys help I found this out, so I put some5w oil in the fuel, not much, and literally after driving it around for 5 min the hard idle, dieing, and white smoke stopped. It runs great, I feel like it runs as good as a new truck! I am really happy and just thought id let you all no and thank you all for your help, exp. Towcat. Future plans, I'm going to put in new injectors, injector pump and return lines, and get some 5in straight pipes with a bigger exhaust.....thanks again for all your help, I will get pics up soon!
Thanks again, mario
Ps. Truck has 290k with new steering box, new bearings, and some more and the engine has abou 80k....worth it?
Thanks again, mario
