cm1hedge
I have a friend that has a 1997 F-350 with a no start problem. The Injector Driver and ECM were both changed. I just did Valve cover gaskets and harnesses. The IPR plug and wires were shorted to each other. The scanner shows 165 psi to the injectors. If I do a KOEO test, I get a 1283 code. I am suspecting a shorted IPR. Any suggestions? Thanks.
