trythis
Having trouble with this thing overheating change the water pump change the radiator all looks good .
I also scoped the cylinder walls could see carbon on the top of each cylinder all cylinders look the same all cylinders have 120 PSI compression test
I've got no idea where to go from here.
Do not see any bubbles coming up the radiator
Truck only gets hot when you work it hard.
Tell me what else you need to know thank you
