When I was flushing out all the oil in the coolant from the Oil Cooler puking oil.
I did 6 flushes with Cascade and the 6 with Distilled water to get it cleaned out.
I used those 2 drain plugs and the Radiator pet-*******. (Drain thingy)
I didn`t have to remove the Starter. I have the power master 9050, maybe it is shorter than the stock one? IDK.
Pick up one of those black plastic pans from HD over in the side they sell the concrete. it is a mixing pan 3ft X 2ft or so. Drain into it.
You do not have the radiator drain, but any one else reading this, I put a piece of hose on the Pet-******* (Drain thingy) and let it go into the pan, this way it wasn`t running on the frame etc...
Edit: had to redo the dirty word. :sorry:
Dang, 3rd try and dinged me again. :frustrate
screwhead
Austin, TX
I did not remove the starter, cut out a piece of plastic to sit over it for when I drain that side, also had a bright idea of just loosening it a little until it drips out in the future. Might take some time but thought someone might find it useful.
tke395
