1990 International DT360
Status
Not open for further replies.
BrandonMag
Dana 50 rebuilder
Oregon east
I bought this from Ron (defecater) about two years ago in Iowa. Here's the build thread: https://www.oilburners.net/threads/dt360-the-beginning.72437/
My life has taken an unexpected turn, and my wife and I are moving out of the house we just bought seven months ago. Nothing bad has happened, just a change in priorities.
I pulled it running out of a F350 Ron had it in with plans to do pretty much the same. I sold the Eaton transmission that was behind it, but the bellhousing and clutch are still there. Send me a PM and I'll get back to you as soon as I can.
https://portland.craigslist.org/clc/pts/6188110351.html
BrandonMag
Dana 50 rebuilder
Oregon east
I still have this:
International DT360 out of a 1990 school bus. It had about 90K miles on it when pulled. Has a freshly rebuilt Bosch A injection pump and new stock injectors with less than 2K miles. I had the shaft on the water pump custom machined to reduce the length by about an inch and a half. I also swapped to an agricultural harmonic balancer; the OEM bus balancer is HUGE and takes up too much space to fit in a pickup. (The OEM balancer is included.) There's also an International manual for this engine; if and when it needs work, you'll have all the information you need.
I bought to put in a Ford F350 that I sold. Long story short: I bought it from a guy who put a fair amount of time and money into it. He had it in a 1992 Ford F350 crew cab which ran and drove, but he had problems with the clutch. (I believe this has a SAE #3 bellhousing.) My plan was to put out 500-600 horses. It has the stock Garrett turbo on it; I was seriously considering twin-turboing it by running a HX-50 atmosphere.
There's a great company that makes adapter plates for these so you can run a Ford ZF6, E4OD, 4R100, etc.:
https://www.carsonstaufferdiesel.com/products/dt360-adaptor-plate
Some good information about turning these engines up can be found here:
http://www.freewebs.com/nevrenufhp/
Rebuild kits for these can be found for about $1K:
http://www.agkits.com/International-Navistar-DT360-Engine-Inframe-Overhaul-Rebuild-Kit.aspx#
Life has taken a different turn than expected; we've moved and don't have the space we used to. I've sold pretty much everything, and I don't need it anymore.
Price is $1500, not interested in trades.
PM me and I will get back to you as soon as I can.
Status
Lance
