Hi All,
I am a new member and have enjoyed learing all about my new toy. a 1987 6.9 crew cab T-19 4.10 DRW. My problem is the way it stops. The Truck now has new pads, rear shoes, wheel cylinders, Axle seales were bad so I changed them too. I have also replaced the vacume pump with oem and the brake booster Adjusted and fulley bled. I will tell you I own a race shop and this stuff should be no big deal. I may just be to fussy but this thing is just not a great stoper. The pedal is high and firm and stops well under normal conditions, problem is when you stop hard the pedal seems to hit a hard spot and the stoping power goes away and you have to push like hell. I will be pulling a 30ft trailer and think they should perfome better. You guys seem to know these trucks better than anyone. Is this normal?
Is the new vacume booster defective? Thanks in advance!
John
John
