1986 C20 DIESEL SUBURBAN, $700.00....
LOGANSTANFORTH
700$$ bucks and its yours, 22X,*** miles, im the 3rd owner, 2nd owner had it 13 years and pulled a 2 stall horse trailer with it once a month, 1st owner never pulled anything with it, transmission is a completely rebuilt turbo 400 with about 5K miles (cost the second owner $3500), J code 6.2 liter diesel, 8 new injectors with about 5K miles on them, starter was rebuilt not long after that at a local starter shop.....has a 14 bolt semi-float rearend with 4.10 gears.....along with the deal ill include 2 brand new rotors, calipers, and brake lines i removed from another 3/4 ton truck (truck only had about 30 miles on those components).....its also got a new master cylinder and power steering pump on the suburban......has ok tires on factory steel wheels and a reese hitch......its red with white tutone except the hood and driver side fender.......you can fit a 4x8 sheet of plywood inside it and shut the doors if you lay the back seat down......truck has a salvage title cause the second owner clipped a new F150 with it and totaled the F150 but the suburban walked away with sheet metal damage (insurance totaled it because it was so old), it has a silver hood, primer fender, its missing the grille right now and has a different bumper on it but the grille and bumper will be fixed before its sold, there was no frame damage just sheetmetal damage.....its got 2 decent sized dents at the back corner of each side of the roof, and the interior it pretty dirty from being a "farm" truck, it could also use some REAR brake work......i dont need it any longer and its taking up space.....it hauled my 5K pound 1st gen dodge home from north carolina at 70 mph, it will easily run with traffic on the freeway at 70+.......THIS WOULD MAKE A GREAT WORK TRUCK, IT AINT PRETTY, IT AINT FAST, BUT IT WILL WORK FOR YOU......
EMAIL ME AT [email protected] or call John Stanforth @ 863-581-5951
its located in lakeland florida......
ill post pics of it tomorrow......
LOGANSTANFORTH
ill let the aluminum wheels go for an extra 100.....
Studebaker62
