crewchief219
I had to change my oil cooler because my pressure regulator valve was stuck open and dumping oil into the oil pan. I think everyone here has a point that because your pressure seems to be affected by the angle of your truck that its prob not your issue but if you want to see all you have to do is pull your oil filter and look through the square opening. You'll see what looks like a cylinder. You shouldn't see any sort of hole, but if you do then you can try to close it with a scribe or really skinny screwdriver. Mine wouldn't move at all and I had to replace it but that's one thing to eliminate.
