1-4 lbs of boost on banks turbo
Chrismohan
St. Petersburg
I just installed a used banks sidewinder turbo on my 89 f350 7.3. Im only getting1-4 lbs of boost. I installed the same setup on my 86 with a 6.9 and its night and day. Probably getting 13 lbs of boost on the 6.9. I have no muffler just a straight pipe to the front of the rear wheel. Is that too much restriction. Should i make it shorter. Does the fuel need to be turned up. Its the same system, whats wrong
Macrobb
North Idaho
Yup; no boost without fuel.
I had my 88 tuned for best performance without smoke back when it was NA; finally got and installed a Banks kit and the result was... underwhelming.
It only helped a little at high RPMs.
Then I cranked the fuel.... Night and day difference.
Sidewinded_idi
Yucaipa ca
I have the sidewinder kit and it was hard to boost and would top out at 6psi. I disconnected the wastegate and boosts much better. But I also need more fuel
